<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[.daa support]]></title><description><![CDATA[<p dir="auto">It would be nice if PA supported .daa files (Direct-Access-Archive).</p>
]]></description><link>https://forums.powerarchiver.com/topic/1941/daa-support</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 14:13:42 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1941.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 04 Dec 2006 13:58:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to .daa support on Tue, 10 Apr 2007 16:46:31 GMT]]></title><description><![CDATA[<p dir="auto">Hello again,<br />
the .daa has been explained already. needed to install PowerIso to be able to extract the .daa file.<br />
Checked whether ‘the competion’ like Winzip supports .daa extraction, but i donot think so.</p>
<h1>brgds</h1>
]]></description><link>https://forums.powerarchiver.com/post/14343</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14343</guid><dc:creator><![CDATA[wulffra]]></dc:creator><pubDate>Tue, 10 Apr 2007 16:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to .daa support on Tue, 10 Apr 2007 09:25:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">what is daa?</p>
<p dir="auto">Checked <a href="http://mark0.net/soft-trid-deflist-d.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://mark0.net/soft-trid-deflist-d.html</a></p>
<p dir="auto">leading to <a href="http://www.poweriso.com/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.poweriso.com/</a></p>
<p dir="auto">@poweriso:</p>
<p dir="auto">DAA(Direct-Access-Archive) is an advanced format for image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes. It can be handled directly just like other formats, such as ISO, BIN, …</p>
<p dir="auto">Firstb time I’ve come across it, though :confused:</p>
]]></description><link>https://forums.powerarchiver.com/post/14342</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14342</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 10 Apr 2007 09:25:18 GMT</pubDate></item><item><title><![CDATA[Reply to .daa support on Mon, 09 Apr 2007 12:16:30 GMT]]></title><description><![CDATA[<p dir="auto">what is daa?</p>
]]></description><link>https://forums.powerarchiver.com/post/14337</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14337</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 09 Apr 2007 12:16:30 GMT</pubDate></item><item><title><![CDATA[Reply to .daa support on Mon, 09 Apr 2007 05:59:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel" aria-label="Profile: Daniel">@<bdi>Daniel</bdi></a>:</p>
<p dir="auto">Yep! I wud like to support this. Hope it will be available in one of the next releases…</p>
]]></description><link>https://forums.powerarchiver.com/post/14335</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/14335</guid><dc:creator><![CDATA[wulffra]]></dc:creator><pubDate>Mon, 09 Apr 2007 05:59:10 GMT</pubDate></item></channel></rss>
