<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Auto Update bug on specific click sequence]]></title><description><![CDATA[<p dir="auto">If you go to the “Auto Update” configuration option and click the “Check For Update” button, The “PowerArchiver 2007 Web Update” dialog appears. Now:<br />
1. Click Close, on the aforementioned dialog, then<br />
2. Click <strong>Cancel</strong> on the Configuration dialog</p>
<p dir="auto">Now if you run update checking, either by again clicking “Check for Update” via the Auto Update configuration tab, or by click “Check for new version…” via the 'Help" dropdown, there is no response.</p>
<p dir="auto">The only way to restore behavior is to restart PowerArchiver. This bug does not occur if, after having clicked “Check For Update” and performed Step #1 above, you click <strong>OK</strong> on the Configuration dialog.</p>
<p dir="auto">WinXP SP2 + PA 10.00.14</p>
]]></description><link>https://forums.powerarchiver.com/topic/1925/auto-update-bug-on-specific-click-sequence</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 07:59:42 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1925.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Nov 2006 13:13:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Auto Update bug on specific click sequence on Fri, 01 Dec 2006 09:00:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks welhaux!</p>
<p dir="auto">The issue should be fixed in Beta 3.</p>
]]></description><link>https://forums.powerarchiver.com/post/12901</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12901</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Fri, 01 Dec 2006 09:00:13 GMT</pubDate></item><item><title><![CDATA[Reply to Auto Update bug on specific click sequence on Wed, 29 Nov 2006 14:31:33 GMT]]></title><description><![CDATA[<p dir="auto">In classic interface, I can see the problem…</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/12852</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12852</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Nov 2006 14:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to Auto Update bug on specific click sequence on Wed, 29 Nov 2006 14:22:03 GMT]]></title><description><![CDATA[<p dir="auto">no problems under windows 2000.</p>
<p dir="auto">Do you use any antivirus or firewalls</p>
]]></description><link>https://forums.powerarchiver.com/post/12848</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12848</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 29 Nov 2006 14:22:03 GMT</pubDate></item></channel></rss>
