<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 2007 UI Suggestion]]></title><description><![CDATA[<p dir="auto">Just a minor suggestion on the UI for the Configuration dialog in PA 2007 (Beat 2).</p>
<p dir="auto">The button corresponding to the current configuration page should be highlighted in some fashion (bold the text, keep the button colored, make the button appear pushed, or something) so that when I’m working my way down the list I don’t have to re-establish where I am.</p>
]]></description><link>https://forums.powerarchiver.com/topic/1924/pa-2007-ui-suggestion</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 14:22:01 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1924.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Nov 2006 18:39:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 2007 UI Suggestion on Tue, 05 Dec 2006 03:02:16 GMT]]></title><description><![CDATA[<p dir="auto">oh, in the powerarchiver queue application, the font is still MS Sans Sherif… you should fix that, too :)</p>
]]></description><link>https://forums.powerarchiver.com/post/12966</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12966</guid><dc:creator><![CDATA[rev23dev]]></dc:creator><pubDate>Tue, 05 Dec 2006 03:02:16 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 UI Suggestion on Fri, 01 Dec 2006 10:18:37 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">The buttons in Configuration window will now look “selected”.</p>
<p dir="auto">We will see if we will add Black skin for final version.</p>
]]></description><link>https://forums.powerarchiver.com/post/12910</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12910</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Fri, 01 Dec 2006 10:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 UI Suggestion on Thu, 30 Nov 2006 21:24:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rev23dev" aria-label="Profile: rev23dev">@<bdi>rev23dev</bdi></a>:</p>
<p dir="auto">Also, the caption needs Glass in Vista Aero :)</p>
<p dir="auto">and a Black skin, like Office 2007</p>
<p dir="auto">the main menu in the ribbon could use a little work, too.</p>
<p dir="auto">work is always done… glass in Modern toolbar not soo soon (it is done on small border), black skin we can do, but it doesnt look good when we do it… then again, Office doesnt have MyPA skin either, does it? :-).</p>
]]></description><link>https://forums.powerarchiver.com/post/12889</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12889</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 30 Nov 2006 21:24:57 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 UI Suggestion on Thu, 30 Nov 2006 19:52:24 GMT]]></title><description><![CDATA[<p dir="auto">Also, the caption needs Glass in Vista Aero :)</p>
]]></description><link>https://forums.powerarchiver.com/post/12887</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12887</guid><dc:creator><![CDATA[rev23dev]]></dc:creator><pubDate>Thu, 30 Nov 2006 19:52:24 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2007 UI Suggestion on Wed, 29 Nov 2006 20:48:50 GMT]]></title><description><![CDATA[<p dir="auto">Interesting idea, we will see if we can do it… thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/12868</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12868</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Nov 2006 20:48:50 GMT</pubDate></item></channel></rss>
