<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unzipping multiple password-protected files?]]></title><description><![CDATA[<p dir="auto">I have a backup set created by a different program that contains a few thousand files, in which each file is compressed and encrypted individually with the standard ZIP algorithm and AES-256. There is also a directory structure.</p>
<p dir="auto">Example:<br />
Directory 1 - file 1.zip<br />
file 2.zip<br />
file 3.zip<br />
Subdirectory 1 - file 1.zip<br />
file 2.zip<br />
file 3.zip<br />
Directory 2 - file 1.zip<br />
file 2.zip<br />
file 3.zip<br />
file 4.zip<br />
and so on</p>
<p dir="auto">Now, I would to extract a couple of hundred files from this backup with PowerArchiver (I do not like the restoration procedure that this other program offers).</p>
<p dir="auto">I have two problems:</p>
<p dir="auto">a) PowerArchiver asked me for the password for each file. However, the password is the same for every file in the backup set. Can I make PowerArchiver remember the password and only ask me again if a different password is required within an unzipping session?</p>
<p dir="auto">b) The existing directory structure got lost. All files - no matter which directory they were located in - were extracted into one single directory. Can I do anything about that?</p>
]]></description><link>https://forums.powerarchiver.com/topic/1876/unzipping-multiple-password-protected-files</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 14:05:50 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1876.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Nov 2006 13:39:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unzipping multiple password-protected files? on Sun, 19 Nov 2006 10:12:43 GMT]]></title><description><![CDATA[<p dir="auto">OK, good to know. Thanks for your replies.</p>
]]></description><link>https://forums.powerarchiver.com/post/12716</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12716</guid><dc:creator><![CDATA[Zipperman]]></dc:creator><pubDate>Sun, 19 Nov 2006 10:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to Unzipping multiple password-protected files? on Sun, 19 Nov 2006 00:19:42 GMT]]></title><description><![CDATA[<p dir="auto">ah, yes - PPM works per file :-).</p>
<p dir="auto">I believe that upcoming PA 2007 will have some changes to help in this case.</p>
]]></description><link>https://forums.powerarchiver.com/post/12713</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12713</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 19 Nov 2006 00:19:42 GMT</pubDate></item><item><title><![CDATA[Reply to Unzipping multiple password-protected files? on Sat, 18 Nov 2006 17:12:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">a. At this point you can use PPM? (check options)<br />
b. what about using extract to filename\subfolder?</p>
<p dir="auto">a) I looked into the options and the password manager is enabled (i.e. there is a cross in the appropriate checkbox). But still PowerArchiver does not remember the password, I have to enter it for every archive. What could be the reason for that?<br />
All the archive (ZIP) files have different names, but that shouldn’t be a problem, right? They all have the same password.</p>
<p dir="auto">Since it is folder with many subfolders and many individually compressed ZIP files, I went to PowerArchiver’s Tools and used its multi-unpack function (I am not sure if that is the right term, I have a German version here).</p>
]]></description><link>https://forums.powerarchiver.com/post/12712</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12712</guid><dc:creator><![CDATA[Zipperman]]></dc:creator><pubDate>Sat, 18 Nov 2006 17:12:10 GMT</pubDate></item><item><title><![CDATA[Reply to Unzipping multiple password-protected files? on Sat, 18 Nov 2006 02:12:07 GMT]]></title><description><![CDATA[<p dir="auto">a. At this point you can use PPM? (check options)<br />
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/12711</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12711</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 18 Nov 2006 02:12:07 GMT</pubDate></item></channel></rss>
