<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Impossible Password set on PBS file]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I just registered PA a few weeks ago. I set up an autobackup file and tried opening one today. None of my passwords (4 digit) opened it. when I looked in the PBS file I found a password set to: ¿7ü*›±(Í?ù½o²îã4±A</p>
<p dir="auto">I don’t know how that was set, I don’t even know how to make most of those characters. but when I copied it from the pbs to the zip password prompt it opened.</p>
<p dir="auto">I am thinking this could be a dangerous bug or problem for people. Please advise</p>
]]></description><link>https://forums.powerarchiver.com/topic/1723/impossible-password-set-on-pbs-file</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Mar 2026 12:53:03 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1723.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 23 Sep 2006 20:20:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Impossible Password set on PBS file on Mon, 25 Sep 2006 18:17:33 GMT]]></title><description><![CDATA[<p dir="auto">can you send us that .pbs file? Either to support at conexware . com, or attach it to the forums.</p>
<p dir="auto">Epassword is new password which is encrypted. Password is previous password that was used in earlier versions and is not encrypted.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/12151</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12151</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 25 Sep 2006 18:17:33 GMT</pubDate></item><item><title><![CDATA[Reply to Impossible Password set on PBS file on Mon, 25 Sep 2006 17:32:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">I was under the impression that when storing the password in the pbs file, it is encrypted :cool:</p>
<p dir="auto">Hence, the item in the pbs file is “Epassword” - not just Password.</p>
<p dir="auto">However, that doesn’t explain why it worked via copy/paste into password field :confused:</p>
<p dir="auto">I set the password to something entirely different.</p>
<p dir="auto">and “Epassword” doesn’t open the file if I use it in the “enter password” textbox.</p>
]]></description><link>https://forums.powerarchiver.com/post/12145</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12145</guid><dc:creator><![CDATA[Blarneystone]]></dc:creator><pubDate>Mon, 25 Sep 2006 17:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to Impossible Password set on PBS file on Mon, 25 Sep 2006 09:02:37 GMT]]></title><description><![CDATA[<p dir="auto">I was under the impression that when storing the password in the pbs file, it is encrypted :cool:</p>
]]></description><link>https://forums.powerarchiver.com/post/12141</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12141</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 25 Sep 2006 09:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Impossible Password set on PBS file on Mon, 25 Sep 2006 00:46:43 GMT]]></title><description><![CDATA[<p dir="auto">I started with 9.63</p>
]]></description><link>https://forums.powerarchiver.com/post/12140</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12140</guid><dc:creator><![CDATA[Blarneystone]]></dc:creator><pubDate>Mon, 25 Sep 2006 00:46:43 GMT</pubDate></item><item><title><![CDATA[Reply to Impossible Password set on PBS file on Sun, 24 Sep 2006 01:33:20 GMT]]></title><description><![CDATA[<p dir="auto">what version of PowerArchiver were you using before?Or did you start with 9.63?</p>
]]></description><link>https://forums.powerarchiver.com/post/12135</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/12135</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 24 Sep 2006 01:33:20 GMT</pubDate></item></channel></rss>
