<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pa 2006?]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I’m looking at purchasing, but have a few questions.</p>
<p dir="auto">When encrypting/ decrypting is any problems with AV, Spyware program running in real time protection guard. I use Nod32 and it’s always scanning, just wondering if this would interfere.</p>
<p dir="auto">I need to send SFX files through email. Is this easy enough to do?</p>
<p dir="auto">Thanks</p>
<p dir="auto">Rilla927</p>
]]></description><link>https://forums.powerarchiver.com/topic/1629/pa-2006</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 19:22:08 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1629.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Aug 2006 17:33:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pa 2006? on Mon, 28 Aug 2006 15:23:09 GMT]]></title><description><![CDATA[<p dir="auto">If you are usign Outlook, you could use our plugin, which has an feature than renames last letter of the extension, so mail servers would not block it.</p>
<p dir="auto">It also supports creating SFX’s.</p>
]]></description><link>https://forums.powerarchiver.com/post/11815</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11815</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 28 Aug 2006 15:23:09 GMT</pubDate></item><item><title><![CDATA[Reply to Pa 2006? on Mon, 28 Aug 2006 04:42:28 GMT]]></title><description><![CDATA[<p dir="auto">@NTFS:</p>
<p dir="auto">Hi!</p>
<p dir="auto">I’d used Nod32 and had no problems with PowerArchiver.<br />
What about sending SFX files through email – PowerArchiver is not Email client but it has feature that can send archives.</p>
<p dir="auto">Oh, some how I missed that.</p>
<p dir="auto">But problem is that most Email Servers reject .exe attachments because of security reasons (Viruses, Spyware, etc) so you may want to sand “normal” (non SFX) archives with “normal” archive extensions (.zip .7z …)</p>
<p dir="auto">Ya, you’re right about the .exe being detected through the servers. I forgot about that. Thanks for pointing these things out.</p>
]]></description><link>https://forums.powerarchiver.com/post/11812</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11812</guid><dc:creator><![CDATA[Rilla927]]></dc:creator><pubDate>Mon, 28 Aug 2006 04:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to Pa 2006? on Mon, 28 Aug 2006 03:50:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi!</p>
What about sending SFX files through email – PowerArchiver is not Email client but it has feature that can send archives. But problem is that most Email Servers reject .exe attachments because of security reasons (Viruses, Spyware, etc) so you may want to sand “normal” (non SFX) archives with “normal” archive extensions (.zip .7z …)</p>
]]></description><link>https://forums.powerarchiver.com/post/11811</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11811</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Mon, 28 Aug 2006 03:50:52 GMT</pubDate></item></channel></rss>
