<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Archive Converter bug - 7-ZIP]]></title><description><![CDATA[<p dir="auto">When converting to 7-ZIP ultra, the memory usage is around 200 MB - that’s not ultra, it’s more like maximum!</p>
]]></description><link>https://forums.powerarchiver.com/topic/1619/archive-converter-bug-7-zip</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:38:44 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1619.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Aug 2006 07:29:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Archive Converter bug - 7-ZIP on Wed, 16 Aug 2006 15:29:44 GMT]]></title><description><![CDATA[<p dir="auto">try doing 2 conversions - one with maximum and one with ultra settings and see if they are the same size wise…</p>
]]></description><link>https://forums.powerarchiver.com/post/11746</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11746</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 16 Aug 2006 15:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to Archive Converter bug - 7-ZIP on Wed, 16 Aug 2006 10:47:47 GMT]]></title><description><![CDATA[<p dir="auto">The archive type to convert from is irrelevant - PA extracts to temp first.<br />
Size of data was about 500 MB, even tried 2GB.<br />
Task Manager shows the memory usage.<br />
Didn’t try manual compression for comparison.</p>
<p dir="auto">The point is that Ultra uses 700 MB of memory for compression, not 200!! 200 is what maximum uses!<br />
The compression takes long enough, so that the memory usage should reach its peak of 700.</p>
<p dir="auto">Any thoughts?</p>
]]></description><link>https://forums.powerarchiver.com/post/11742</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11742</guid><dc:creator><![CDATA[Shivan]]></dc:creator><pubDate>Wed, 16 Aug 2006 10:47:47 GMT</pubDate></item><item><title><![CDATA[Reply to Archive Converter bug - 7-ZIP on Wed, 16 Aug 2006 10:36:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/shivan" aria-label="Profile: Shivan">@<bdi>Shivan</bdi></a>:</p>
<p dir="auto">Didn’t realise this was question :p</p>
<p dir="auto">Converting from ??<br />
Size of data (uncompressed) ?<br />
How are you measuring the memory usage ?<br />
If you compress the data with 7z(ultra) is the resulting archive different to the converted file?</p>
<p dir="auto">Edit: If you compress the data with 7z(maximum) is the resulting archive different to the converted file?</p>
]]></description><link>https://forums.powerarchiver.com/post/11741</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11741</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Wed, 16 Aug 2006 10:36:50 GMT</pubDate></item><item><title><![CDATA[Reply to Archive Converter bug - 7-ZIP on Wed, 16 Aug 2006 10:04:44 GMT]]></title><description><![CDATA[<p dir="auto">Anybody??</p>
]]></description><link>https://forums.powerarchiver.com/post/11740</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11740</guid><dc:creator><![CDATA[Shivan]]></dc:creator><pubDate>Wed, 16 Aug 2006 10:04:44 GMT</pubDate></item></channel></rss>
