<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Naming ZIP files]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am having some problems and not sure what I am doing.</p>
<p dir="auto">I have a loads of files all named “001.WAV”, “002.WAV”, “003.WAV” etc but if I try to ZIP them one by one it names the ZIP file “downloads.ZIP” instead of “001.ZIP”, “002.ZIP”, “003.ZIP” etc.</p>
<p dir="auto">Thankyou</p>
]]></description><link>https://forums.powerarchiver.com/topic/1573/naming-zip-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 08:50:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1573.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Jun 2006 11:54:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Naming ZIP files on Tue, 20 Jun 2006 09:45:54 GMT]]></title><description><![CDATA[<p dir="auto">One .wav file plus one .txt is two files :D<br />
Therefore, PowerArchiver default is to use the folder name for the Zip file.</p>
<p dir="auto">I think the easiest way to accomplish what you want would be to use the “command line” utility PACL.</p>
<p dir="auto">Then you could create a simple command (aka DOS BOX) or a batch file with a “for” loop.</p>
<p dir="auto">e.g. something like:-<br />
“FOR %F IN (*.wav) DO PACOMP -a %F.zip %F.wav read.txt”</p>
<p dir="auto">see also <a href="http://www.powerarchiver.com/forums/showthread.php?t=100" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/forums/showthread.php?t=100</a></p>
]]></description><link>https://forums.powerarchiver.com/post/11485</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11485</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 20 Jun 2006 09:45:54 GMT</pubDate></item><item><title><![CDATA[Reply to Naming ZIP files on Mon, 19 Jun 2006 12:06:51 GMT]]></title><description><![CDATA[<p dir="auto">I ZIP up one of the WAV files at a time but also I put a TXT file in with each ZIP file.</p>
<p dir="auto">EG - 001.WAV + Read.TXT = 001.ZIP</p>
]]></description><link>https://forums.powerarchiver.com/post/11482</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11482</guid><dc:creator><![CDATA[DaveTomneyUK]]></dc:creator><pubDate>Mon, 19 Jun 2006 12:06:51 GMT</pubDate></item><item><title><![CDATA[Reply to Naming ZIP files on Mon, 19 Jun 2006 11:55:49 GMT]]></title><description><![CDATA[<p dir="auto">how are you zipping them one by one? usually folder name is used when there are several files selected…</p>
]]></description><link>https://forums.powerarchiver.com/post/11481</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11481</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 19 Jun 2006 11:55:49 GMT</pubDate></item></channel></rss>
