<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Relative Directories]]></title><description><![CDATA[<p dir="auto">I created a new ZIP archive and opened it. Now I added differnt files from different directories with the optin relative directories (I have the german version and don’t know the translation in english – it is the left option in the add dialog). In the main PA window are no path dispalyed (if I use the option complete directories, all informations are displayed).<br />
After unpacking the files where all in one directory. Is it a bug … ???</p>
<p dir="auto">Thanks for helping</p>
]]></description><link>https://forums.powerarchiver.com/topic/1534/relative-directories</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 09:49:07 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1534.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 May 2006 14:49:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Relative Directories on Sun, 28 May 2006 14:57:54 GMT]]></title><description><![CDATA[<p dir="auto">if you are adding file alone, then relative path will not be saved, because there is no relative path.</p>
<p dir="auto">You are adding file:<br />
D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\Daten\test.txt</p>
<p dir="auto">Its root folder is:<br />
D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\Daten</p>
<p dir="auto">So there is no relative path to add.</p>
<p dir="auto">If you were adding:<br />
D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\Daten\test.txt<br />
D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\file.exe</p>
<p dir="auto">Then root would be:<br />
D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\</p>
<p dir="auto">and path Daten would be stored for test.txt. Relative path is never created based on where you create the archive, since that could be anywhere…</p>
]]></description><link>https://forums.powerarchiver.com/post/11385</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11385</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 28 May 2006 14:57:54 GMT</pubDate></item><item><title><![CDATA[Reply to Relative Directories on Sun, 28 May 2006 10:48:45 GMT]]></title><description><![CDATA[<p dir="auto">1. I start PA.<br />
2. I say New<br />
3. I create a new archive in the following directory : D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2 called UP060528.zip<br />
4. I add a file from a subdirectory of the created zip archive ( D:\Projekte\SB\EExport2\Deutsch\FSC\EExport2\Daten ).<br />
5. After adding the file to the archive the the sub directory \Daten will not displayed.<br />
6. If I unpack the archive, is in the main unpacking directory.</p>
]]></description><link>https://forums.powerarchiver.com/post/11383</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11383</guid><dc:creator><![CDATA[MrBlues]]></dc:creator><pubDate>Sun, 28 May 2006 10:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to Relative Directories on Wed, 24 May 2006 10:22:42 GMT]]></title><description><![CDATA[<p dir="auto">can you detail more info on what exactly are you doing?</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/11361</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11361</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 24 May 2006 10:22:42 GMT</pubDate></item><item><title><![CDATA[Reply to Relative Directories on Mon, 22 May 2006 09:02:48 GMT]]></title><description><![CDATA[<p dir="auto">Hallo, I tried like you discribed… but it don’t works! I changed the option in the attachment disppalys. I also checked the help, but this option is missing in the help.</p>
<p dir="auto">thanks for helping<br />
<img src="/uploads/_imported_attachments/attachment_p_7415_0_bild2.jpg" alt="attachment_p_7415_0_bild2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/11339</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11339</guid><dc:creator><![CDATA[MrBlues]]></dc:creator><pubDate>Mon, 22 May 2006 09:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to Relative Directories on Mon, 22 May 2006 08:35:15 GMT]]></title><description><![CDATA[<p dir="auto">hi,</p>
<p dir="auto">you need to enable option: Config&gt; Misc&gt; Use normal path.<br />
and it should work as you suggested.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/11338</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/11338</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 22 May 2006 08:35:15 GMT</pubDate></item></channel></rss>
