<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[9.5 Skins under 9.6 &amp; Skin Request]]></title><description><![CDATA[<p dir="auto">Is it not possible to use 9.5 SKN files under 9.6?</p>
<p dir="auto">The new skin engine is nice but performance wise, I prefer the more simple skins such as Longhorn for 9.5.</p>
<p dir="auto"><strong>Skin authors:</strong> Here is a request for something simple and clean. No sound effects or rollups. I just want to unzip my files :)</p>
<p dir="auto">Small file size + clean images. The basics.</p>
]]></description><link>https://forums.powerarchiver.com/topic/1429/9-5-skins-under-9-6-skin-request</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:16:10 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1429.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 29 Mar 2006 03:42:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 9.5 Skins under 9.6 &amp; Skin Request on Wed, 29 Mar 2006 09:35:39 GMT]]></title><description><![CDATA[<p dir="auto">That might be worth a try. What is WB? Do you happen to have a link by chance?</p>
<p dir="auto">Thanks for the idea!</p>
]]></description><link>https://forums.powerarchiver.com/post/10836</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10836</guid><dc:creator><![CDATA[MarcFou]]></dc:creator><pubDate>Wed, 29 Mar 2006 09:35:39 GMT</pubDate></item><item><title><![CDATA[Reply to 9.5 Skins under 9.6 &amp; Skin Request on Wed, 29 Mar 2006 08:46:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marcfou" aria-label="Profile: MarcFou">@<bdi>MarcFou</bdi></a>:</p>
<p dir="auto">Hi,</p>
<p dir="auto">you cant use them under 9.6, since it is completly different skin engine. Of course, there is an longhorn skin for WB that you could use, but you have to download it and install it manually since it is not made for PA specifically…</p>
]]></description><link>https://forums.powerarchiver.com/post/10830</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10830</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 29 Mar 2006 08:46:31 GMT</pubDate></item></channel></rss>
