<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA fails to run after install on non-admin accounts]]></title><description><![CDATA[<p dir="auto">I use PA at my university. Students have a limited user account.<br />
I always install PA to the desktop, since I have write access there.</p>
<p dir="auto">When I install PA 9.6 (beta 2 or 3), I get file error messages on WBHELP2.DLL and WBOCX.OCX, access is denied, so cannot write to windows directory.</p>
<p dir="auto">Now when I try running PA, PA crashes with “PowerArchiver 2006 has encountered…… We are sorry for the inconvenience.”</p>
<p dir="auto">I can bet that the WindowBlinds skin engine is causing this! Even if I remove all PA entries from the registry (the admin missed something…), or delete the Skins folder, it still happens.<br />
No other version of PA does this, but 9.6.</p>
<p dir="auto">I dunno how this can be solved; maybe you shouldn’t initialize the skin engine if there is no skin selected, which is the default.</p>
<p dir="auto">PS: why not install the WB files in the PA dir? PA is the only app that needs to use those files!</p>
]]></description><link>https://forums.powerarchiver.com/topic/1427/pa-fails-to-run-after-install-on-non-admin-accounts</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 10:18:41 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1427.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Mar 2006 11:35:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA fails to run after install on non-admin accounts on Wed, 29 Mar 2006 06:59:29 GMT]]></title><description><![CDATA[<p dir="auto">OK, the problem is solved - PA runs!!!</p>
<p dir="auto">If I try to select a skin, nothing happens!!</p>
<p dir="auto">Great work!!! ;-)</p>
]]></description><link>https://forums.powerarchiver.com/post/10824</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10824</guid><dc:creator><![CDATA[Shivan]]></dc:creator><pubDate>Wed, 29 Mar 2006 06:59:29 GMT</pubDate></item><item><title><![CDATA[Reply to PA fails to run after install on non-admin accounts on Wed, 29 Mar 2006 06:51:23 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">Until the problem is fully resolved, I’ll have to use 9.51 on campus and 9.6 at home… :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/10823</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10823</guid><dc:creator><![CDATA[Shivan]]></dc:creator><pubDate>Wed, 29 Mar 2006 06:51:23 GMT</pubDate></item><item><title><![CDATA[Reply to PA fails to run after install on non-admin accounts on Tue, 28 Mar 2006 22:19:54 GMT]]></title><description><![CDATA[<p dir="auto">With 9.6 final, PA will skip around missing dll’s and continue working…</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/10814</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10814</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 28 Mar 2006 22:19:54 GMT</pubDate></item><item><title><![CDATA[Reply to PA fails to run after install on non-admin accounts on Tue, 28 Mar 2006 16:14:08 GMT]]></title><description><![CDATA[<p dir="auto">we cant add it to any other folder. Thats the way it works. So you have to have an admin account to install it.</p>
]]></description><link>https://forums.powerarchiver.com/post/10810</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10810</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 28 Mar 2006 16:14:08 GMT</pubDate></item></channel></rss>
