<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zip failure]]></title><description><![CDATA[<p dir="auto">Using PowerArchiver 9.60 beta2</p>
<p dir="auto">Think I have found a bug in the latest beta.</p>
<p dir="auto">For testing purposes I created 3 folders: testa,testb,testc. Each containing one text file.</p>
<p dir="auto">I then tried to create a new archive with these folders.</p>
<p dir="auto">Created a new Zip archive called test and added these 3 folders then clicked finish. Result no files in the archive and no Zip archive created either.</p>
<p dir="auto">Used the same 3 folders and created all other archive formats with no problem. It is only a Zip that fails.</p>
<p dir="auto">Interestingly enough if I create a Zip archive and click finish after adding one folder and then each subsequent folder the archive is fine.</p>
<p dir="auto">Also if I highlight the folders in explorer and use the shell extension “Compress With Options” then the Zip archive is created as normal.</p>
<p dir="auto">luxor</p>
]]></description><link>https://forums.powerarchiver.com/topic/1406/zip-failure</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 21:44:20 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1406.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Mar 2006 18:37:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zip failure on Mon, 27 Mar 2006 18:36:14 GMT]]></title><description><![CDATA[<p dir="auto">great, closing the thread!</p>
]]></description><link>https://forums.powerarchiver.com/post/10802</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10802</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 27 Mar 2006 18:36:14 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Mon, 27 Mar 2006 17:26:28 GMT]]></title><description><![CDATA[<p dir="auto">Fixed in PowerArchiver 2006 9.6 Beta 3 :)</p>
<p dir="auto">Luxor</p>
]]></description><link>https://forums.powerarchiver.com/post/10801</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10801</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Mon, 27 Mar 2006 17:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Wed, 15 Mar 2006 14:21:49 GMT]]></title><description><![CDATA[<p dir="auto">thanks for extra info, its probably something to do with Advanced Add window, since we improved it in Betas… I will check it out.</p>
]]></description><link>https://forums.powerarchiver.com/post/10769</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10769</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 15 Mar 2006 14:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Wed, 15 Mar 2006 12:42:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">i have followed his instructions by using context menues and powerarchiver itself all ways you can do so with pa and results prove that there is no problem however tried with ultimatezip and problem is there</p>
<p dir="auto">are u using this program instead</p>
<p dir="auto">windows 2000 tested on</p>
<p dir="auto">If I was I would be posting in the ultimatezip forum wouldn’t I. :rolleyes:</p>
<p dir="auto">Seriously though, Powerarchiver is the only Archiver I use and the only one that has ever been on my computer. No need for anything else. :D</p>
]]></description><link>https://forums.powerarchiver.com/post/10768</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10768</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Wed, 15 Mar 2006 12:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Wed, 15 Mar 2006 12:38:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Hi,</p>
<p dir="auto">please tell us how exactly did you create the zip file (options, was it advanced add window, was normal relative path enabled, etc)</p>
<p dir="auto">I can not reproduce it on my test computer.</p>
<p dir="auto">thanks,</p>
<p dir="auto">Hi Spywolf.</p>
<p dir="auto">Otions: Advanced Add Window enabled. Normal Reletive Path disabled. Anything else you need from options ?</p>
<p dir="auto">When adding a folder to the archive I was using “Store relative paths”.</p>
<p dir="auto">Did another test but this time using “Store full paths” and that one worked fine.<br />
Tried again using “Do not store paths”, fine once again.<br />
So it appears to be only when the “Store relative paths” option is used in the Add window.</p>
<p dir="auto">Should have mentioned using XP Home SP2 all up to date.</p>
<p dir="auto">Hope this helps</p>
]]></description><link>https://forums.powerarchiver.com/post/10767</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10767</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Wed, 15 Mar 2006 12:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Tue, 14 Mar 2006 23:02:49 GMT]]></title><description><![CDATA[<p dir="auto">i have followed his instructions by using context menues and powerarchiver itself all ways you can do so with pa and results prove that there is no problem however tried with ultimatezip and problem is there</p>
]]></description><link>https://forums.powerarchiver.com/post/10762</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10762</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 14 Mar 2006 23:02:49 GMT</pubDate></item><item><title><![CDATA[Reply to Zip failure on Tue, 14 Mar 2006 21:06:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
]]></description><link>https://forums.powerarchiver.com/post/10761</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10761</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 14 Mar 2006 21:06:01 GMT</pubDate></item></channel></rss>
