<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#96;t upgrade from PA 2004 to 2006!]]></title><description><![CDATA[<p dir="auto">Hello!<br />
After receiving the new Registration key for PA 2006, I tried to upgrade my existing German(!) installation of PA 2004 (Vers. 9.26). After installing I type in the new registration key for PA 2006 (German) exactly as it was sent. The message appears, that for successful registration I have to restart PowerArchiver, but after restarting it is like before: The registration window appears and I`m asked to type in the registation key, and so on…<br />
Is there a workaround or something?<br />
Thanks for your help!</p>
<p dir="auto">Kind regards,<br />
Dirk</p>
]]></description><link>https://forums.powerarchiver.com/topic/1394/can-t-upgrade-from-pa-2004-to-2006</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 07:21:02 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1394.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2006 16:46:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#96;t upgrade from PA 2004 to 2006! on Fri, 10 Mar 2006 02:06:20 GMT]]></title><description><![CDATA[<p dir="auto">not a problem, closing it.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/10751</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10751</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 10 Mar 2006 02:06:20 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#96;t upgrade from PA 2004 to 2006! on Tue, 07 Mar 2006 10:46:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks! The first point helped me!<br />
I logged in to my account, and re-downloaded my registration key(s) for PA 2006 and in this Email were two keys. The first Email, a few months ago, contained only one key. This (first) key, as I have tested yesterday, worked with the english version, but not with the german version. :)<br />
Thanks again for your help!<br />
Kind regards,<br />
Dirk</p>
]]></description><link>https://forums.powerarchiver.com/post/10742</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10742</guid><dc:creator><![CDATA[soerdoerk]]></dc:creator><pubDate>Tue, 07 Mar 2006 10:46:13 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#96;t upgrade from PA 2004 to 2006! on Mon, 06 Mar 2006 17:00:57 GMT]]></title><description><![CDATA[<p dir="auto">Few things:</p>
<ul>
<li>make sure you are entering International code</li>
<li>make sure both code and registration name is written exactly as in your order email.</li>
</ul>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/10740</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10740</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 06 Mar 2006 17:00:57 GMT</pubDate></item></channel></rss>
