<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Version number]]></title><description><![CDATA[<p dir="auto">I like the version number being on the download file. :)</p>
]]></description><link>https://forums.powerarchiver.com/topic/136/version-number</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 12:06:21 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/136.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Aug 2004 20:39:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Version number on Sun, 15 Aug 2004 02:46:51 GMT]]></title><description><![CDATA[<p dir="auto">You are right. I noticed it too! ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/6083</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6083</guid><dc:creator><![CDATA[Charles Botz]]></dc:creator><pubDate>Sun, 15 Aug 2004 02:46:51 GMT</pubDate></item><item><title><![CDATA[Reply to Version number on Fri, 13 Aug 2004 19:49:14 GMT]]></title><description><![CDATA[<p dir="auto">Yes, but prior to this release the file had been powarc900 no matter which version when you saved it. Now when you use the update and save the file, it includes the version number so if you have an issue you can go back to an earlier version.</p>
]]></description><link>https://forums.powerarchiver.com/post/6079</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6079</guid><dc:creator><![CDATA[amh209]]></dc:creator><pubDate>Fri, 13 Aug 2004 19:49:14 GMT</pubDate></item><item><title><![CDATA[Reply to Version number on Fri, 13 Aug 2004 18:07:13 GMT]]></title><description><![CDATA[<p dir="auto">it is if you use the update feature within powerarchiver found on the help menu</p>
]]></description><link>https://forums.powerarchiver.com/post/6078</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/6078</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Fri, 13 Aug 2004 18:07:13 GMT</pubDate></item></channel></rss>
