<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Purchase + Question]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">1. I purchased Power Archiver 9.51, does this enable me to free updates of later versions?</p>
<p dir="auto">2. When will the next version be due out and will it support it so you can make self extracting .EXE files?</p>
<p dir="auto">EG - So you can make instead of like .ZIP files it lets you compress .EXE files as well.</p>
<p dir="auto">Thank You</p>
]]></description><link>https://forums.powerarchiver.com/topic/1358/purchase-question</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:48:16 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1358.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Feb 2006 20:17:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Purchase + Question on Sun, 05 Feb 2006 17:57:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davetomneyuk" aria-label="Profile: DaveTomneyUK">@<bdi>DaveTomneyUK</bdi></a>:</p>
<p dir="auto">I purchased a personal license so it means I can upgrade to PA2007+ free?</p>
<p dir="auto">Yes, you will get ALL Future updates for free!</p>
]]></description><link>https://forums.powerarchiver.com/post/10600</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10600</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Sun, 05 Feb 2006 17:57:25 GMT</pubDate></item><item><title><![CDATA[Reply to Purchase + Question on Sun, 05 Feb 2006 09:44:00 GMT]]></title><description><![CDATA[<p dir="auto">I purchased a personal license so it means I can upgrade to PA2007+ free?</p>
<p dir="auto">As for the EXE thing I found it.</p>
<p dir="auto">Thanks</p>
<p dir="auto">PS - I have used a lot of ZIP programs and I have to say this PA is the best by far and its cheap at only $20.</p>
]]></description><link>https://forums.powerarchiver.com/post/10597</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10597</guid><dc:creator><![CDATA[DaveTomneyUK]]></dc:creator><pubDate>Sun, 05 Feb 2006 09:44:00 GMT</pubDate></item><item><title><![CDATA[Reply to Purchase + Question on Sun, 05 Feb 2006 00:12:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Business licenses have free 2 next major updates - PA 2007 and PA 2008 and all of their updates, while personal licenses (for personal use) have unlimited free upgrades.</p>
<p dir="auto">As to the SFX, terry said it right - you can already do that.</p>
]]></description><link>https://forums.powerarchiver.com/post/10594</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10594</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 05 Feb 2006 00:12:54 GMT</pubDate></item><item><title><![CDATA[Reply to Purchase + Question on Sat, 04 Feb 2006 21:23:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davetomneyuk" aria-label="Profile: DaveTomneyUK">@<bdi>DaveTomneyUK</bdi></a>:</p>
<p dir="auto">Of course, I don’t work for Conexware, so<br />
I suppose that ‘technically’ the license is for PowerArchiver 2006. An “upgrade” which is given the name PowerArchiver 2007 may not be free.</p>
<p dir="auto">However, going by history - everyone who paid for the license has had free upgrades since PowerArchiver introduced licenses - which was PowerArchiver v8 (in 2001). :)</p>
<p dir="auto">You can do this now (for Zip and CAB) - look at the menu ‘Tools / SFX Wizard’. :D<br />
Or if you already have a zip/cab, you can use the shell options (Explorer - right click) to create an SFX from it.<br />
;)</p>
]]></description><link>https://forums.powerarchiver.com/post/10592</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10592</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sat, 04 Feb 2006 21:23:55 GMT</pubDate></item></channel></rss>
