<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[.pae files?]]></title><description><![CDATA[<p dir="auto">Hey guys, im new to this and i have not purchased PowerArchiver, but a friend has sent me a file in .pae format, how exactly would i go about decrypting that file without powerarchiver? thanks :cool:</p>
]]></description><link>https://forums.powerarchiver.com/topic/1334/pae-files</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 14:29:00 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1334.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jan 2006 22:51:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to .pae files? on Thu, 02 Feb 2006 20:27:17 GMT]]></title><description><![CDATA[<p dir="auto">i am closing this thread. You can open an new thread in Wishlist if you want to discuss whatever you want to discuss :-).</p>
<p dir="auto">a. You can create SFX PAE<br />
b. Anyone can download and use PA2006 to extract PAE</p>
<p dir="auto">Those two answered original question, anything else is some new feature.</p>
<p dir="auto">thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/10575</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10575</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 02 Feb 2006 20:27:17 GMT</pubDate></item><item><title><![CDATA[Reply to .pae files? on Thu, 02 Feb 2006 19:05:01 GMT]]></title><description><![CDATA[<p dir="auto">pae is great cause it can be used on files that do not need compression or files that simply are groups of different compssed archives. i think they have the wrong approach pae is far far better than any other encryption.</p>
<p dir="auto">You add files to pae after compression where as the zip or 7zip aes you have to do it at the creation of the archive.</p>
<p dir="auto">what does everyone else think?</p>
]]></description><link>https://forums.powerarchiver.com/post/10573</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10573</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Thu, 02 Feb 2006 19:05:01 GMT</pubDate></item><item><title><![CDATA[Reply to .pae files? on Thu, 02 Feb 2006 18:36:04 GMT]]></title><description><![CDATA[<p dir="auto">Well, there are PAE SFX’s now, which make it easy to distribute PAE archives. As well as the fact that anyone can download and use PA2006.</p>
<p dir="auto">We dont plan to issue dll’s, since in fact, we think zip aes and 7zip aes are sufficient for everyone. PAE was made before zip aes existed and when zip’s encryption was very weak.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/10571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10571</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 02 Feb 2006 18:36:04 GMT</pubDate></item><item><title><![CDATA[Reply to .pae files? on Thu, 02 Feb 2006 18:22:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">when will you be able to decrypt pae files without powerarchiver?</p>
<p dir="auto">Maybe when PA developers will make some “UnPAE DLL” and some other software use it to decrypt these files</p>
]]></description><link>https://forums.powerarchiver.com/post/10569</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10569</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Thu, 02 Feb 2006 18:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to .pae files? on Thu, 02 Feb 2006 17:31:13 GMT]]></title><description><![CDATA[<p dir="auto">when will you be able to decrypt pae files without powerarchiver?</p>
]]></description><link>https://forums.powerarchiver.com/post/10568</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10568</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Thu, 02 Feb 2006 17:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to .pae files? on Tue, 31 Jan 2006 05:20:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phyzc" aria-label="Profile: Phyzc">@<bdi>Phyzc</bdi></a>:</p>
<p dir="auto">Hi,<br />
There is no way (at least official) to decrypt .pae file without PowerArchiver… So you may download PA Trial for free from <a href="http://www.powerarchiver.com/download/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/download/</a> and extract it…<br />
Maybe then you would want to make your own pae files and other archives and you purchase PA - the best archiver in the world :D</p>
<p dir="auto">Serhiy</p>
]]></description><link>https://forums.powerarchiver.com/post/10548</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10548</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Tue, 31 Jan 2006 05:20:43 GMT</pubDate></item></channel></rss>
