<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Opening split tar.gz file]]></title><description><![CDATA[<p dir="auto">I downloaded a backup from my server that was tar.gz compressed and also split into 2. The file names are foo.tar.gzaa and foo.tar.gzab</p>
<p dir="auto">PA opens foo.tar.gzaa but says that foo.tar.gzab does not appear to ba a valid archive. it also suggests too open the last files in a series, which, as far as I know, gzab is.</p>
]]></description><link>https://forums.powerarchiver.com/topic/1273/opening-split-tar-gz-file</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 16:14:50 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1273.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Nov 2005 07:19:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Opening split tar.gz file on Sun, 20 Nov 2005 18:38:45 GMT]]></title><description><![CDATA[<p dir="auto">This is not standard splitted GZIP archive, nor GZIP supports spliting. So I think this backup utility splits files in it’s own way - just file/size splitting.</p>
<p dir="auto">You can create joined archive even under command line:</p>
<p dir="auto">copy /b file.gza + file.gzb + file.gzc file.gz</p>
<p dir="auto">and then open file.gz. Try this.</p>
]]></description><link>https://forums.powerarchiver.com/post/10364</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10364</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sun, 20 Nov 2005 18:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to Opening split tar.gz file on Sun, 20 Nov 2005 16:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moganero" aria-label="Profile: Moganero">@<bdi>Moganero</bdi></a>:</p>
<p dir="auto">The backup utility on the the server splits the backup files if requested (various file-size otions). It’s a linux server and has 4PSA Client Backup installed on it. That’s all I know!</p>
<p dir="auto">Sorry, don’t know this utility.<br />
<p dir="auto">“foo” isn’t the actual name - that was too long to bother typing, the extensions were as they were generated by 4PSA Client Backup.</p>
<p dir="auto">Yes, I understood that, ‘foo’ wasn’t the strange bit - it is the extensions, .gzaa; .gzab etc.</p>
<p dir="auto">I guess ( :confused: ) that it may be a simple file splitter, not a “compression” splitter. If so, maybe you just use a “Join” utility to combine them again into single tar.gz file.</p>
<p dir="auto">Of course, copy them before trying this - just in case.</p>
]]></description><link>https://forums.powerarchiver.com/post/10363</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10363</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 20 Nov 2005 16:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to Opening split tar.gz file on Sun, 20 Nov 2005 14:40:32 GMT]]></title><description><![CDATA[<p dir="auto">The backup utility on the the server splits the backup files if requested (various file-size otions). It’s a linux server and has 4PSA Client Backup installed on it. That’s all I know!</p>
]]></description><link>https://forums.powerarchiver.com/post/10362</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10362</guid><dc:creator><![CDATA[Moganero]]></dc:creator><pubDate>Sun, 20 Nov 2005 14:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to Opening split tar.gz file on Sun, 20 Nov 2005 10:17:15 GMT]]></title><description><![CDATA[<p dir="auto">Yes, how the files are splitted? Using gzip or some other file-splitter utility?</p>
<p dir="auto">… since, I see this for the first time.</p>
]]></description><link>https://forums.powerarchiver.com/post/10361</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10361</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sun, 20 Nov 2005 10:17:15 GMT</pubDate></item><item><title><![CDATA[Reply to Opening split tar.gz file on Sun, 20 Nov 2005 09:16:06 GMT]]></title><description><![CDATA[<p dir="auto">Unusual filenames for split archives.<br />
How did you “split them” originally?</p>
]]></description><link>https://forums.powerarchiver.com/post/10360</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10360</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 20 Nov 2005 09:16:06 GMT</pubDate></item></channel></rss>
