<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Strange lockup bug after updating]]></title><description><![CDATA[<p dir="auto">I deinstalled V9.x something and installed 9.50.<br />
Got new key etc. rebooted some times.</p>
<p dir="auto">Now if I click on any Archive and select “unpack”<br />
or something, or even when I try to start pa.exe<br />
directly over the start menu, explorer.exe goes<br />
up to 99% simply locking the whole pc as long Pa.exe<br />
is running. It seems the explorer calling code is<br />
going mad somewhere …</p>
<p dir="auto">I uninstalled 9.50 several times and reinstalled it, but<br />
no avail. I went back to 9.x because of this strange<br />
buggy…</p>
<p dir="auto">WinXP2 with all actual fixes. No explorer plugins except<br />
tortoiseSVN.</p>
<p dir="auto">Im puzzled :confused:</p>
<p dir="auto">+mzk</p>
]]></description><link>https://forums.powerarchiver.com/topic/1242/strange-lockup-bug-after-updating</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 15:25:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1242.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Oct 2005 19:12:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Strange lockup bug after updating on Thu, 03 Nov 2005 22:05:28 GMT]]></title><description><![CDATA[<p dir="auto">thats pretty and fast from f-prot, kudos to them!</p>
]]></description><link>https://forums.powerarchiver.com/post/10294</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10294</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 03 Nov 2005 22:05:28 GMT</pubDate></item><item><title><![CDATA[Reply to Strange lockup bug after updating on Thu, 03 Nov 2005 16:59:55 GMT]]></title><description><![CDATA[<p dir="auto">For the record:</p>
<p dir="auto">I uploaded teh PA.exe to F-Prot and they send me<br />
a nice mail that they looking into it (31. Oct 05)</p>
<p dir="auto">With the update of today (03. November 2005)<br />
(which seemed to be a little larger than usual)<br />
the timeout/locking of the machine handling archives<br />
was complete gone. If I click on a zip or want to<br />
unpack it, it runs like it should on my A64 :p</p>
<p dir="auto">Cased closed.</p>
<p dir="auto">-mzk</p>
]]></description><link>https://forums.powerarchiver.com/post/10287</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10287</guid><dc:creator><![CDATA[mzk]]></dc:creator><pubDate>Thu, 03 Nov 2005 16:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Strange lockup bug after updating on Tue, 25 Oct 2005 20:52:16 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">We are using some compression/encryption on our EXE file in 9.5, but so far we haven’t found any problems with most anti-virus programs, so please inform us when you get any reply from F-PROT support.</p>
]]></description><link>https://forums.powerarchiver.com/post/10224</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10224</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Tue, 25 Oct 2005 20:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to Strange lockup bug after updating on Tue, 25 Oct 2005 20:41:24 GMT]]></title><description><![CDATA[<p dir="auto">That hit the spot - somehow.</p>
<p dir="auto">I found out, that f-prot needs about 20secs cpuload<br />
to scan trough powerarchiver.exe (all other files,<br />
even much larger exe up to 20mb it flys over in a sec).</p>
<p dir="auto">Then I updated the .exe of f-prot to the newest version<br />
(16c from 16a) this delay got down of about 1/3 of the<br />
old version time.</p>
<p dir="auto">Im puzzled, because I run fprot for 3 years now and thisis the first time the realtimeprotector chokes on a file :rolleyes: It’s on all time and does a very good job.</p>
<p dir="auto">Unfortunately, there is no way to turn off protections<br />
for certain files/dirs in f-prot now as written in the<br />
faq:</p>
<p dir="auto"><a href="http://www.f-prot.com/support/windows/fpwin_faq/31.html" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.f-prot.com/support/windows/fpwin_faq/31.html</a></p>
<p dir="auto">Since f-prot makes updates nearly every day to their signature files, I would make sense to send them the powerarchiver.exe so they can investigate the problem.</p>
<p dir="auto">Since the delay is bugging but “acceptable” for now, I will live with it and report any factfindings/update from f-prot to this thread for further reference.</p>
]]></description><link>https://forums.powerarchiver.com/post/10223</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10223</guid><dc:creator><![CDATA[mzk]]></dc:creator><pubDate>Tue, 25 Oct 2005 20:41:24 GMT</pubDate></item><item><title><![CDATA[Reply to Strange lockup bug after updating on Tue, 25 Oct 2005 19:41:30 GMT]]></title><description><![CDATA[<p dir="auto">That is strange.<br />
Do you have AntiVirus that could be conflicting with PA?<br />
Maybe exclude PA directory from RunTime checking or whatever the option is.</p>
]]></description><link>https://forums.powerarchiver.com/post/10222</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10222</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Tue, 25 Oct 2005 19:41:30 GMT</pubDate></item></channel></rss>
