<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 2006 New skins not as they appear on skins page.]]></title><description><![CDATA[<p dir="auto">I downloaded 2 new skins from the new skin section for PowerArchiver 2006.<br />
The Darker Circle skin and the Longhorn skin.</p>
<p dir="auto">On the skins page the tool-bars have a sliver/grey background. But when I have them installed I get a blue background on the tool-bars as you can see from the attached screen-shots.</p>
<p dir="auto">Other skins appear to be OK so wonder why these skins appear different.</p>
<p dir="auto">Anyone else get this or is it just me.</p>
<p dir="auto">Luxor<br />
<img src="/uploads/_imported_attachments/attachment_t_1243_0_darker-circle-skin-toolbar.gif" alt="attachment_t_1243_0_darker-circle-skin-toolbar.gif" class=" img-fluid img-markdown" /><br />
<img src="/uploads/_imported_attachments/attachment_t_1243_1_longhorn-skin-toolbar.gif" alt="attachment_t_1243_1_longhorn-skin-toolbar.gif" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/1206/pa-2006-new-skins-not-as-they-appear-on-skins-page</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 11:42:38 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1206.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Oct 2005 11:36:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 2006 New skins not as they appear on skins page. on Mon, 10 Oct 2005 15:39:19 GMT]]></title><description><![CDATA[<p dir="auto">ok, so bg changes only if XP themes are enabled (screenshot was taken on system that has it disabled). So you SHOULD get the blue bg (looks better too). It depends on the skin actually.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/10129</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10129</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 10 Oct 2005 15:39:19 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2006 New skins not as they appear on skins page. on Mon, 10 Oct 2005 15:33:27 GMT]]></title><description><![CDATA[<p dir="auto">what OS are you using?</p>
]]></description><link>https://forums.powerarchiver.com/post/10127</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10127</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 10 Oct 2005 15:33:27 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2006 New skins not as they appear on skins page. on Mon, 10 Oct 2005 11:33:28 GMT]]></title><description><![CDATA[<p dir="auto">How come it is only with these two skins that I am seeing this behaviour. ?<br />
Every other skin appears to be as it looks on the skins page.</p>
<p dir="auto">Changing to default is not the answer as then I get just that, the default but no skin.</p>
<p dir="auto">If you mean select default then select a skin, I have already tried that but the blue background reappears.</p>
<p dir="auto">Luxor</p>
]]></description><link>https://forums.powerarchiver.com/post/10126</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10126</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Mon, 10 Oct 2005 11:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to PA 2006 New skins not as they appear on skins page. on Sun, 09 Oct 2005 18:03:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/luxor" aria-label="Profile: Luxor">@<bdi>Luxor</bdi></a>:</p>
<p dir="auto">The skins do not include the toolbar. Not sure why the Toolbar background changes but it happens with most of them. If you change the toolbar this will change/reset the background of the toolbar icons.<br />
E.g. Default -&gt; Default (large) -&gt; Default</p>
]]></description><link>https://forums.powerarchiver.com/post/10122</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10122</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 09 Oct 2005 18:03:17 GMT</pubDate></item></channel></rss>
