<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PowerArchiver 9.50.26 File &#x2F; Find Archives badly broken]]></title><description><![CDATA[<p dir="auto">The “File / Find Archives” functionality is not working and there is missing functionality that would help diagnose the error/issue.</p>
<p dir="auto">Enhancement request. First, it would be very helpful to be able to point the “find archives” at a specific folder to “recurse” down rather than at the whole computer or a specific archive.</p>
<p dir="auto">Bug. My version doesn’t allow me to point to a specific drive, the drop down where the drive is supposed to be is blank and the drop down menu contain no entries.</p>
<p dir="auto">Bug. I pointed the find files to search the whole PC. It found a handful of archives when I known from a thorough file by file directory listing that there are at least 155 archives of types ZIP GZ TAR and Z. Huge data integrity issue here, folks.</p>
]]></description><link>https://forums.powerarchiver.com/topic/1205/powerarchiver-9-50-26-file-find-archives-badly-broken</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 20:45:22 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1205.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Oct 2005 04:34:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PowerArchiver 9.50.26 File &#x2F; Find Archives badly broken on Sun, 09 Oct 2005 18:41:39 GMT]]></title><description><![CDATA[<p dir="auto">Drop down issue is fixed in final release :-).</p>
<p dir="auto">I am moving rest to the wishlist.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/10123</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10123</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 09 Oct 2005 18:41:39 GMT</pubDate></item><item><title><![CDATA[Reply to PowerArchiver 9.50.26 File &#x2F; Find Archives badly broken on Sun, 09 Oct 2005 14:14:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">Note: when stopped, it displayed the results in a window titled “Favorite Folders” :confused:<br />
Edit: OOPS - This is correct - see help file.</p>
<p dir="auto">By the way, could this ‘Found results window’ be made resizable please?<br />
It is awkward with both long filenames and long pathnames.</p>
<p dir="auto">yea, I agree.<br />
I got quite surprised to see the search result archives in the favorite folder as well…</p>
]]></description><link>https://forums.powerarchiver.com/post/10119</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10119</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sun, 09 Oct 2005 14:14:49 GMT</pubDate></item><item><title><![CDATA[Reply to PowerArchiver 9.50.26 File &#x2F; Find Archives badly broken on Sun, 09 Oct 2005 13:46:25 GMT]]></title><description><![CDATA[<p dir="auto">It’s high likely that there are some “file type association” things going on. I’ll check &lt;br /&gt;that .  I was uninstalling and installing various alternatives to PA all day.  I’m trying to search a dataset of 100,000+ files and PA is the only partial solution to use for this application.  My motivation:&lt;br /&gt;&lt;br /&gt;1.  There’s no way to automatically delete archive files that have been expanded&lt;br /&gt;     as opposed to those archive files that may have been nested in other archive &lt;br /&gt;     files and not yet expanded themselves.  (Back to DOS script files, UGH!)&lt;br /&gt;&lt;br /&gt;2.  Many archive files contain other archive files and PA does not expand recursively&lt;br /&gt;     in one pass.  (About 10% go a second pass, about 5% of them to a third pass)&lt;br /&gt;     The data volumes in some of these situations are significant for me.&lt;br /&gt;&lt;br /&gt;3.  There is not a way to expand the contents of the archive in the folder in which the &lt;br /&gt;     archive is located AND automatically rename files that share the same name to &lt;br /&gt;     limit path “length growth”.   This otherise results in the loss of 75% of my original &lt;br /&gt;     data if I try to expand archives without expanding the archive filepath structure.&lt;br /&gt;     Not a great alternative.&lt;br /&gt;&lt;br /&gt;    Note:  If I try to expand WITH the orginal path, I occasionally run into total path &lt;br /&gt;    length issues &gt; 255.  PA emits incorrect error messages and doesn’t necessarily &lt;br /&gt;    understand that something bad has happened.   A prescreening function that &lt;br /&gt;    checked and genarated a “check log” would be extremely helpful.  Otherwise,&lt;br /&gt;    I have to do this manually using Excel spreadsheets.&lt;br /&gt;&lt;br /&gt;4.  Logging is not sufficient to track the number of original archive files, track the &lt;br /&gt;     files that were expanded from each, including situations where there are multiple&lt;br /&gt;    levels of nested archives.  What would be helpful would be:&lt;br /&gt;&lt;br /&gt;    Tab-indented archive format that could be imported into Microsoft Access or Excel:&lt;br /&gt;&lt;br /&gt;   &lt;timestamp&gt; &lt;action&gt; &lt;nesting level, 0-n&gt; &lt;loose filepath+filename&gt; &lt;br /&gt;   &lt;archive filepath+filename&gt;&lt;br /&gt;   &lt;br /&gt;   Where action would include terms such as “extracted” “deleted” &lt;added&gt;&lt;br /&gt;   etc.</p>
]]></description><link>https://forums.powerarchiver.com/post/10118</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10118</guid><dc:creator><![CDATA[sf_flyboy]]></dc:creator><pubDate>Sun, 09 Oct 2005 13:46:25 GMT</pubDate></item><item><title><![CDATA[Reply to PowerArchiver 9.50.26 File &#x2F; Find Archives badly broken on Sun, 09 Oct 2005 10:07:40 GMT]]></title><description><![CDATA[<p dir="auto">I have never used this feature, but now I tried it.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sf_flyboy" aria-label="Profile: sf_flyboy">@<bdi>sf_flyboy</bdi></a>:</p>
<p dir="auto">Confirmed.<br />
“File - Find Archives - Search only drive”<br />
Same in both Classic and Explorer View.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sf_flyboy" aria-label="Profile: sf_flyboy">@<bdi>sf_flyboy</bdi></a>:</p>
<p dir="auto">Bug. I pointed the find files to search the whole PC. It found a handful of archives when I known from a thorough file by file directory listing that there are at least 155 archives of types ZIP GZ TAR and Z.</p>
<p dir="auto">Not confirmed.<br />
In my case it quickly found over 800 archives, before I stopped it. {7z, Cab, Zip, ISO, Tar, bz2}<br />
Edit: From Help file -<br />
“PowerArchiver will search for all formats it supports”<br />
So I guess this could mean only archive types, you have associated with PA ?</p>
]]></description><link>https://forums.powerarchiver.com/post/10117</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10117</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Sun, 09 Oct 2005 10:07:40 GMT</pubDate></item></channel></rss>
