<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Encrypting Backup Express Archives]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am evaluating PowerArchiver and find the PABE functionality extermely useful - especially to backup files to a FTP site. However, I am not able to encrypt the zip file as part of the script. I can set a password on the zip file, but this displays the contents of the archive and only prompts when extracting from archive.</p>
<p dir="auto">Is there a way to zip, encrypt and ftp through a script using PowerArchiver?</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Amarpai</p>
]]></description><link>https://forums.powerarchiver.com/topic/1172/encrypting-backup-express-archives</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 08:13:47 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1172.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Sep 2005 23:40:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Thu, 29 Sep 2005 06:57:50 GMT]]></title><description><![CDATA[<p dir="auto">The workaround was good enough - just purchased a copy and very pleased with it!!!</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">Yes, the normal ZIP password is not very secure and you can find “cracking” utilities on the internet.</p>
<p dir="auto">In this discussion thread, we are using encryption to refer to the “AES encryption” options for ZIP compression (as spwolf said).</p>
<p dir="auto">Note: in PowerArchiver there is also “PA encryption” - this is also as secure as AES, but cannot be invoked from PA Backup Express Lite.</p>
]]></description><link>https://forums.powerarchiver.com/post/10042</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10042</guid><dc:creator><![CDATA[amarpai]]></dc:creator><pubDate>Thu, 29 Sep 2005 06:57:50 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Mon, 26 Sep 2005 08:25:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amarpai" aria-label="Profile: amarpai">@<bdi>amarpai</bdi></a>:</p>
<p dir="auto">What is the difference between the following:</p>
<ol>
<li>Zipping a directory and then encrypting it using menu item.</li>
<li>Using a password while zipping.</li>
</ol>
<p dir="auto">The reason I ask this is because in the past, I have used WinZip and I was told that if you use a password while zipping, this password can easily be hacked.</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://forums.powerarchiver.com/post/10004</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10004</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Mon, 26 Sep 2005 08:25:25 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Mon, 26 Sep 2005 08:10:36 GMT]]></title><description><![CDATA[<p dir="auto">That’s a pretty good idea - think I will use it in the interim.</p>
<p dir="auto">One other question…</p>
<ol>
</ol>
<p dir="auto">A quick (admittedly “dirty”) workaround is to Zip twice.</p>
<p dir="auto">First, combine all directory structure into a single archive.<br />
E.g. TAR or Zip using “store” (i.e. No compression).</p>
<p dir="auto">Then Zip that archive using compression, encryption options required.</p>
<p dir="auto">Thus the only name visible is that of the archive file.</p>
]]></description><link>https://forums.powerarchiver.com/post/10003</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/10003</guid><dc:creator><![CDATA[amarpai]]></dc:creator><pubDate>Mon, 26 Sep 2005 08:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Thu, 22 Sep 2005 13:56:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amarpai" aria-label="Profile: amarpai">@<bdi>amarpai</bdi></a>:</p>
<p dir="auto">Yes, I saw that feature. The problem is that file names are visible. Basically, we want to encrypt a large number of files in a directory structure so that it is not possible to even get a listing of the contents.</p>
]]></description><link>https://forums.powerarchiver.com/post/9973</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9973</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Thu, 22 Sep 2005 13:56:29 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Thu, 22 Sep 2005 11:28:36 GMT]]></title><description><![CDATA[<p dir="auto">Yes, I saw that feature. The problem is that file names are visible. Basically, we want to encrypt a large number of files in a directory structure so that it is not possible to even get a listing of the contents.</p>
<p dir="auto">I have posted this request in the “Wish list” forum as well. Any idea when this particular feature will be available?</p>
]]></description><link>https://forums.powerarchiver.com/post/9972</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9972</guid><dc:creator><![CDATA[amarpai]]></dc:creator><pubDate>Thu, 22 Sep 2005 11:28:36 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Wed, 21 Sep 2005 23:52:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/amarpai" aria-label="Profile: amarpai">@<bdi>amarpai</bdi></a>:</p>
<p dir="auto">hi,</p>
<p dir="auto">you can encrypt the file using zip aes encryption, it is only that the filenames are not hidden…</p>
]]></description><link>https://forums.powerarchiver.com/post/9969</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9969</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 21 Sep 2005 23:52:01 GMT</pubDate></item><item><title><![CDATA[Reply to Encrypting Backup Express Archives on Wed, 21 Sep 2005 18:58:33 GMT]]></title><description><![CDATA[<p dir="auto">Not Yet But There Will Be Soon Please Redo Thread In Wish List</p>
]]></description><link>https://forums.powerarchiver.com/post/9967</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9967</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 21 Sep 2005 18:58:33 GMT</pubDate></item></channel></rss>
