<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t delete files in an archive!]]></title><description><![CDATA[<p dir="auto">I’m using PowerArchiver 2004 V9.25 and I’ve got a problem. Hope, somebody can help me with this…</p>
<p dir="auto">The problem is, that I can not delete files, which are in an archive. I make backups of all my savegames with PowerArchiver. My Backup-Zip-File is nearly 400 MB. Now I want to delete some old savegames and if I choose a file, which I want to delete, the Delete-Button is grey. The Button is inactive. But why?</p>
<p dir="auto">The Zip-File is not write protected. Could it be, that the file is too big??</p>
<p dir="auto">Thanks for your help!</p>
<p dir="auto">Greetz,<br />
JIMMY</p>
]]></description><link>https://forums.powerarchiver.com/topic/1113/can-t-delete-files-in-an-archive</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 14:59:27 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1113.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 22 Aug 2005 10:50:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Wed, 24 Aug 2005 12:26:53 GMT]]></title><description><![CDATA[<p dir="auto">no fault must be administrator privilages required to delete files in archives</p>
]]></description><link>https://forums.powerarchiver.com/post/9647</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9647</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 24 Aug 2005 12:26:53 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 21:06:49 GMT]]></title><description><![CDATA[<p dir="auto">Now it works! I don’t know, if it works because of the new Beta. I installed PA2006, but it didn’t work. So I extracted all of the files, which are in the archive. Then I packed them in a new archive and that’s it - it works!</p>
<p dir="auto">Greetings,<br />
JIMMY</p>
]]></description><link>https://forums.powerarchiver.com/post/9629</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9629</guid><dc:creator><![CDATA[PoooMukkel]]></dc:creator><pubDate>Mon, 22 Aug 2005 21:06:49 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 17:21:59 GMT]]></title><description><![CDATA[<p dir="auto">I will try it, when I’m at home back from work. Then I will let you know!</p>
<p dir="auto">Greetz from Germany,<br />
JIMMY</p>
]]></description><link>https://forums.powerarchiver.com/post/9628</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9628</guid><dc:creator><![CDATA[PoooMukkel]]></dc:creator><pubDate>Mon, 22 Aug 2005 17:21:59 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 16:20:34 GMT]]></title><description><![CDATA[<p dir="auto">Let us know if it does, i think this was changed in 9.5</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/9627</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9627</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 22 Aug 2005 16:20:34 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 12:02:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">works with the zip tutorial.</p>
<p dir="auto">must be something todo with the size or format. Your using zip format.</p>
<p dir="auto">Is the archive read only as this can be the fault in many cases.</p>
<p dir="auto">Zip Tutorial? Where can I find it? No, the archive isn’t read only!</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Try using PA2006 and see if it works.</p>
<p dir="auto">I will do so!</p>
<p dir="auto">Thanks a lot!</p>
]]></description><link>https://forums.powerarchiver.com/post/9623</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9623</guid><dc:creator><![CDATA[PoooMukkel]]></dc:creator><pubDate>Mon, 22 Aug 2005 12:02:37 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 11:23:11 GMT]]></title><description><![CDATA[<p dir="auto">@Jimmy:</p>
JIMMY</p>
]]></description><link>https://forums.powerarchiver.com/post/9620</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9620</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 22 Aug 2005 11:23:11 GMT</pubDate></item><item><title><![CDATA[Reply to Can&#x27;t delete files in an archive! on Mon, 22 Aug 2005 11:20:50 GMT]]></title><description><![CDATA[<p dir="auto">works with the zip tutorial.</p>
]]></description><link>https://forums.powerarchiver.com/post/9619</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9619</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Mon, 22 Aug 2005 11:20:50 GMT</pubDate></item></channel></rss>
