<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem in Backup Express lite]]></title><description><![CDATA[<p dir="auto">Another problem in PA Backup Express Lite:</p>
<p dir="auto">.Tar archives (bzip or gzip) created with a date/time stamp have no program association and cannot be opened by PA. Remove the time/time stamp and they open fine.</p>
<p dir="auto">The old problem with .bh seems to be corrected. Thank you! :)</p>
]]></description><link>https://forums.powerarchiver.com/topic/1088/problem-in-backup-express-lite</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 13:43:15 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/1088.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Aug 2005 11:42:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem in Backup Express lite on Fri, 19 Aug 2005 11:04:01 GMT]]></title><description><![CDATA[<p dir="auto">thanks and closed…</p>
]]></description><link>https://forums.powerarchiver.com/post/9571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9571</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 19 Aug 2005 11:04:01 GMT</pubDate></item><item><title><![CDATA[Reply to Problem in Backup Express lite on Thu, 18 Aug 2005 21:21:35 GMT]]></title><description><![CDATA[<p dir="auto">Yes, fixed in PA 9.5 beta 3</p>
]]></description><link>https://forums.powerarchiver.com/post/9563</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9563</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Thu, 18 Aug 2005 21:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to Problem in Backup Express lite on Tue, 16 Aug 2005 10:56:11 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">The issue should be fixed in BETA 3.</p>
]]></description><link>https://forums.powerarchiver.com/post/9524</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9524</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Tue, 16 Aug 2005 10:56:11 GMT</pubDate></item><item><title><![CDATA[Reply to Problem in Backup Express lite on Thu, 11 Aug 2005 20:19:34 GMT]]></title><description><![CDATA[<p dir="auto">thank you for the report</p>
]]></description><link>https://forums.powerarchiver.com/post/9462</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9462</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 11 Aug 2005 20:19:34 GMT</pubDate></item><item><title><![CDATA[Reply to Problem in Backup Express lite on Thu, 11 Aug 2005 15:59:20 GMT]]></title><description><![CDATA[<p dir="auto">@Charles:</p>
<p dir="auto">.Tar archives (bzip or gzip) created with a date/time stamp have no program association and cannot be opened by PA.</p>
<p dir="auto">When date stamp is used as a suffix then the created Filename is:<br />
“Stamped.tar_20050811175449.bz2”<br />
So I guess the problem is that “Stamped.tar_20050811175449” is not treated/recognised as a TAR file.</p>
<p dir="auto">A quick solution - set the date stamp to prefix :D</p>
]]></description><link>https://forums.powerarchiver.com/post/9439</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9439</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Thu, 11 Aug 2005 15:59:20 GMT</pubDate></item></channel></rss>
